799 heads
799 heads
my bro has a 05 chevy 5.3 FBO cammed (jerico cam from xessive) and since the cam is to big he wants yalls opinion if some 799 heads off the new body 5.3 with just a p&p job and maybe a mill will do the trick to wake up the truck and he also wants to install the TBSS intake. do yall think by doing this it would wake up the truck even more ?? also wat do yall think my compression ratio will be after i do this???if yall aint familiar with the jerico cam its a custom grind 228/232/.588/.595 112lsa
thanks in advance !!
FormerVendor
Would be some decent gains from a good set of ported 799 heads and milling. I would imagine 35+ HP would be a good estimate. With that cam, you can probably mill another .020-.025" pretty easy without having to worry about PTV.
Jon
Jon
