799 heads have 1.59 and 1.55 exhaust valves???
I bought some 799 heads new on eBay a couple months ago, had WCCH mill them 0.022, and I have put about 600 miles on them since. I took them off last night to swap the lifters and springs because I had some annoying lifter tapping on the driver side. On this head I noticed that two of the exhaust valves are 1.55" and two are 1.59". The other head has all 1.59". I think these heads are supposed to have 1.55" exhaust valves. I also measured how far the valve stems stick out of the head and there is a 0.03" spread in the stem height.
What the heck is going on here??? Can I run it as is? This is my daily driver and was hoping to have it buttoned back up tomorrow. I don't really have time to get new heads or valves, or have machine work done. I'm leaning towards just using them as is. There was no obvious issues during the the first 600 miles (unless this is causing the tapping noise which I don't think it is). I may have to use some different length pushrods to get the preload correct with the varying stem heights.
This is what I get for buying heads on eBay, even though they were new
Intake Lifters:
Cylinder Preload
1......... 0.075
2......... 0.083
3......... 0.081
4......... 0.086
5......... 0.084
6......... 0.082
7......... 0.081
8......... 0.078
Exhaust Lifters:
Cylinder Preload
1......... 0.079
2......... 0.067
3......... 0.080
4......... 0.069
5......... 0.066
6......... 0.071
7......... 0.059
8......... 0.075
Cylinders 1 and 3 had the correct exhaust valves, the others were LS3 valves. Also found these marks on the cylinder walls of 5 and 7. Looks like the marks shouldnt affect anything though, they are just above where the rings reach. I filed down the high spots lightly. I could barely fell it with my fingernail, probably only a couple thousandths deep.
#7:
#5:
bbowerman
07-26-2015 10:57 PM
