8.1l injector question
Old 03-01-2009 | 03:14 AM
kgmtech's Avatar
Registered User
Default 8.1l injector question
Was wondering if going with bigger injectors on my 8.1 would help gain some power? motor has just basic bolt on stuff exhaust, air intake, and a blackbear tune.
Old 03-01-2009 | 03:18 AM
Mangled03gmc's Avatar
Baltimore Whore
No the stock ones are fine.. Bigger injectors are needed when the stockers can't supply the fuel that the motor needs, due to blower, turbo's & nitrous. Your injectors will allow you plenty of room to grow, as far as hp goes..
Old 03-01-2009 | 07:12 AM
xx_ED_xx's Avatar
x 2
Old 03-01-2009 | 09:00 AM
kgmtech's Avatar
Registered User
Anyone know what would be a good cam for the 8.1? I see comp cams makes some cams for it,worth using? or any other suggestions?
Old 03-01-2009 | 07:10 PM
xx_ED_xx's Avatar
I was going to use a zz502 cam in mine and repin the wires for the firing order
Old 03-01-2009 | 07:13 PM
Baltimore Whore
I don't think a ZZ502 motor cam will woke in the 496's.. They are totally diff engines, blocks.. http://www.raylarengine.com/ has some good things for the 8.1's
Old 03-01-2009 | 07:44 PM
phasemaster1's Avatar
Their is one guy here that can answer pretty much any question you have on the 8.1l PM Whippled 496.
Old 03-01-2009 | 08:01 PM
kgmtech's Avatar
Registered User
ya i have seen the raylar stuff but they are sky high on their prices....their stuff is all made to work together basically no need to do their cam if you aren't putting theur heads on to.
Old 03-01-2009 | 08:05 PM
Baltimore Whore
Yes your right, but you could prob call up and get some info out of them.. I havn't seen to much aftermarket for them(496)
Old 03-06-2009 | 10:53 AM
hog's Avatar
hog
I am pretty sure a ZZ502 cam will work, you'll just need to swap some low tension coil wires and some injector wires.
The 8.1 is just a tall deck block.
496 = 4.250" x 4.37" (2001 Vortec 8100, 8.1 liter)
502 = 4.466" x 4.00"
peace
Hog
adunphy
02-22-2016 07:38 PM
GrooveCityZ71
08-31-2015 01:05 PM
Raylar Engineering
08-26-2015 11:36 PM
FlowmasterMufflers
08-14-2015 02:04 PM
USMCvet0311
08-01-2015 08:45 AM
