#8 Piston hitting relucter wheel?!?!
Old 04-04-2011, 09:51 PM
Swerve7rpm2000's Avatar
Guys i just wanted to update this just incase someone else runs into the same problem, the skirt of the piston #8 was hitting the relucter wheel when the piston was at the bottom of the cylinder, i marked the spot where it was hitting, took it back out, filed down where it was hitting untill i had decent clearance and it worked just fine. Truck is up and running fine
Old 04-07-2011, 03:43 PM
FormerVendor
Callies Performance's Avatar
Good To Hear!
Old 04-07-2011, 04:10 PM
JFOLM's Avatar
Just for giggles. Do you have a pic showing how much you clearance you gave it?
Old 04-07-2011, 04:42 PM
sure dont man i was told at least 20 thousanths which isnt awhole lot..... Look at your fingernails and stack one on top of the other that would be plenty lol, you actually couldnt see the spot where it was hitting without a mirror and Bright streamlite flashlight
Old 04-07-2011, 08:42 PM
JFOLM's Avatar
Thanks anyways!
5.3Okasai
03-09-2022 01:07 PM
lycominghunter
08-15-2015 12:26 PM
JordanH
08-08-2015 07:59 PM
ferrellrooster
07-13-2015 09:53 AM
Quick Reply: #8 Piston hitting relucter wheel?!?!
