#862 heads
Old 06-22-2007, 07:34 AM
Hunt&Fisherator
silver-mod-o's Avatar
Default #862 heads
What do you know about these. Chamber size? Runner size? valves??
Would it be worth picking a cheap set of these up and having them worked?? maybe milled .030 or so?? I know my cam needs more compression to run like it really should.
I have the stock, untouched 706 castings on the truck now.
Old 06-22-2007, 10:15 AM
YenkoST's Avatar
From everything I have read, the 706 is the better flowing castings and everything else abotu them is virtually the same. Like I said, just from what I've read on this board.
If your interested, I have a set of the 706s that I am trying to sell for cheap if you don't want to mess up your stock heads. PM me if your interested.
Old 06-22-2007, 10:22 AM
FormerVendor
Richard@WCCH's Avatar
They are the equivalent to your 706 heads. Just a different casting number. Reworking them will make a nice power improvement especially with raising the compression.
Good luck,
Richard
Old 06-26-2007, 07:35 AM
Head Casting Info
ALL Gen III heads are interchangable.
Here is a list of a few casting #'s:
933 97 aluminum perimeter bolt 5.7
806 97-98 aluminum perimeter bolt 5.7
853 99-00 aluminum center bolt 5.7
241 01-03 aluminum center bolt 5.7 (some late MY00 cars got 241 castings)
243 LS6 aluminum center bolt 5.7
862 and 706 99 and up 4.8-5.3 truck heads
873 99-00 LQ4 6.0 iron center bolt heads
317 01 and up LQ4 6.0 aluminum center bolt heads
035 02 and up LQ9 6.0 aluminum center bolt heads
Even more info:
Casting Number 241
Head: 1997+ LS1 5.7 Litre Passenger Car
Material: Aluminimum
Part Number:
12559806 (1997-98) Chambers = 69cc
12559853 (1999-00)
12564241 (2001-03)
Combustion Chamber Volume: 66.67cc
Compression Ratio: 10.1:1
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Casting Number 243
Head: 2001 LS6 5.7 Litre Passenger Car
Part Number:
12564243
Combustion Chamber Volume: 64.45cc
Compression Ratio: 10.5:1
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Casting Number 706
Head: 1999+ LR4 4.8 Litre Truck
1999+ LM4 /LM7 5.3 Litre Truck
Part Number:
12559852
12561706
Combustion Chamber Volume: 61.15cc
Compression Ratio: 9.5:1
Intake Valve Diameter: 1.89 inches
Casting Number 373
Head: 1999-2000 LQ4 6.0 Litre Truck
Material: Cast Iron
Part Number:
12561873
Combustion Chamber Volume: 71.06cc
Casting Number 317
Head: 2001+ LQ4 6.0 Litre Truck
Part Number:
12572035
Compression Ratio: 10:1
It takes about .005" milling of the block deck to remove 1cc of volume. It takes .007" milling to remove 1cc from an LS1 head
Simple Milling Math:
You have a stock 66cc chamber and you want to get down to 63cc
66-63 = 3. You have to remove 3cc's
.007 x 3 = .021. So to get your 66cc chambers down to 63cc you'd have to mill ~.021.
You can also do the reverse, say you want to mille a head .030 to figure out how many CC's that removes you take .030 / .007 = ~ 4.28. Milling a stock 5.7 head .030 puts your chamber at ~ 62.
241 cast heads were Die Cast which is a process that smooths up the ports a bit compared to the Sand Cast procedure that was done on the 806 and 853 heads. Once ported any "advantage" the 241 cast had is moot.
lsxmalibu
09-09-2015 11:08 PM
03regcab sierra
09-09-2015 02:02 PM
axekick
09-07-2015 07:01 PM
sauldgold
07-23-2015 02:15 PM
Aboss
07-09-2015 10:28 AM
Quick Reply: #862 heads
