862 vs 243 vs L92 for 5.3
243's w/ a good valve job & a 90mm TBSS intake manifold will work nice. The key will be setting up your valve train properly. Do that & you'll make good power every where.
To be honest it aint worth the swap unless u also port/polish the 243's...
best thing to do is save a little more for a 6.0 swap, since u can find some decent low mileags for $1200-1400
I would do the 862's. They will cost a bit more and give you better results. Milling the 243's will get you down to about stock compression. Milling the 862's can get you to 10:1 or higher and they flow very well ported. Compression is one thing the 5.3L really needs. We did a 5.7L a while back with ported 5.3L heads and made 451RWHP. We took 243's off to put them on.
