862 vs 243 vs L92 for 5.3
Old 08-08-2009, 11:02 PM
  #21
zippy's Avatar
Originally Posted by hirdlej
Who on earth did those heads? Please don't tell me they were TSP's......
Yes they were. These are the heads.
http://texas-speed.com/shop/item.asp?itemid=84&catid=20
It is very commong for the LS1 and LS6 guys to run those heads. The 243's are a very good cylinder head with how well they flow. I'm a big fan of those cylinder heads. The 5.3L only has around 9.5:1 compression though and unless you plan to spray big on it or run boost you might as well go for any compression gain that you can get. The L33 and NNBS 5.3L's running the 243/799 heads all make excellent power from the better heads, more cam, and higher compression due to using the pistons originally designed for the 4.8L. Other than the slight cost difference the choices are fairly obvious. Ported 5.3L heads will outflow 243's and give you more compression.
As for the intake, I'd look for an intake from an 07' and newer 4.8L/5.3L truck and put a 90mm throttle body on it. They are fairly available from those swapping to a Magnacharger. The best one is going to be an intake from a Flex Fuel 5.3L as they will have the larger injectors as part of the deal. The last one I did was a non-Flex Fuel truck and had the larger injectors also, but it doesn't seem to be a sure thing unless it's a Flex Fuel truck.
Old 08-23-2009, 10:18 PM
  #22
Jermoslin's Avatar
Default ?
If you mill say .030" do you have to get shorter pushrods and will the intake ports be mismatched.
  #23
Wearin' da big hat
00ChevyScott's Avatar
they have those rules for a reason.
Old 08-23-2009, 10:21 PM
  #24
Jermoslin's Avatar
Deleate to follow rules
Old 08-23-2009, 10:38 PM
  #25
Baltimore Whore
Mangled03gmc's Avatar
Do the 243's, also the 92's won't work on your engine....
Old 08-23-2009, 10:39 PM
  #26
Wearin' da big hat
we've established that
and I think I'm gonna send my heads to WCCH sometime next year
Old 08-23-2009, 11:56 PM
  #27
dlt76028's Avatar
can i swap a 6.0 in place of my 4.8???
Old 08-24-2009, 12:03 AM
  #28
13 Second Truck Club
A Low Dime's Avatar
What cam should i put in my 5.3? Also, what converter would work best since I will be towing a boat and racing every weekend at the track against camaros?
Old 08-24-2009, 01:58 AM
  #29
Banned
lucky77's Avatar
ported- 243's with a valve job.. should do the job....
Mainesfinest
17
04-07-2016 02:53 PM
03regcab sierra
09-09-2015 02:02 PM
elpyro89
07-28-2015 05:51 PM
steves86ta
07-28-2015 10:21 AM
06 4.8
07-15-2015 07:17 PM
Quick Reply: 862 vs 243 vs L92 for 5.3
