? about boring out 4.8
wats up i have a 4.8 03 silverado i wanted to know how much you can bore it out to and what kind of performance gains i can get from it thanx again cuz i wanted to do that or was considerign a motor swap like an ls1 or somthing
the 4.8 and 5.3 (same block) can be bored to a ls1 bore and then you basically have an iron block ls1. If you had a 5.3 all u would need is pistons. but the 4.8 has a differant crank and rods. all you need is a ls1 rotating assembly and the machine work of course.
4.8 and 5.3 have the same bore. They can be bored to ls1 bore. Throw a crank in it and get a 383....
To the OP, original poster, Search around a bit, ton of info and results on the site....
I've been down this road recently, and came to the conclusion to just buy an LS1 shortblock. it ends up being cheaper than all the machine work on the iron block, and a 4.8 block bored to 3.898 is worth next to nothing if you ever decide to sell it.
If set up correctly. It sounds like you have some homework to do my friend. Get searching
