About to order cam, final thoughts/opinions on setup
I'm about to pull the trigger on my cam. Here's alist of current mods and mods I'll be doing at the time of the cam swap. What do you guys think about this setup and which of the two cams listed below would you guys recommend?
Its my dd, and i tow a bass boat, and haul a harley. I want power from idle to about 6200-6300. I dont wanna lose much low-end. I like a lopey idle
Current:
2005 GMC rcsb
LQ9 4L60E 3:73
LT's, dual 2.5" exhaust, Volant CAI,
corvette servo, billet 4th servo,
160* thermo, tune, plugs/wires
full stereo
Mods at cam swap:
212/218 hi lift on 112 lsa or tsp220/200-112
Springs/rods
stock 243 heads
8.1L marine injectors
and if im lucky at xmas, a CircleD tb stall
Current:
2005 GMC rcsb
LQ9 4L60E 3:73
full stereo
Mods at cam swap:
Springs/rods
stock 243 heads
I've swapped both cams before
here's the 212/218 522 529 -112 +2 (low lift)
https://www.performancetrucks.net/fo...d.php?t=448291
Ap2002 had the high lift on a 112 for a long time.
the TSP 220 will be more aggressive, but better with a TB stall
I've had the 220 in my 4.8 with the stock stall, and did whatever . . . pulled a boat, or hauled gravel or mulch.
