All low end LQ4 cam suggestions?
Old 02-21-2008, 08:31 PM
  #31
InchUp's Avatar
I think that would be a great cam for what he wants. Great lowend and its still going to pull better up top then stock.
That's 2 votes for this cam now, I'll look into it with a 112lsa .
Old 02-21-2008, 09:20 PM
  #32
silveradol33's Avatar
that is my old truck that Zippy posted and my new 06 has 34 inch tires now and I have a tt3000 stall with 456 gears and like mike stated I spin 6400 all day long, I run sand and some mud. In the sand you want wheel speed and u dont get that at 1500 rpm, all 4 wheeling is about wheel speed imo, mud, sand. I would say somthin with a low LSA and a decent amount of duration, around 218 or so? Maybe a TR220? I have owned nothing but lifted trucks my whole life and love rpm. BTW, that blue truck was solid axled right after those pics.
Who said you cant turn a 6.0 over 5500?
Check out all 6k of the 6.0 in the link.
http://s19.photobucket.com/albums/b1...t=100_0668.flv
Old 02-21-2008, 09:51 PM
  #33
InchUp's Avatar
I think I just made my decision then but you guys can keep going with other's suggestions.
I'll stick with the cam CompCAMS suggested in the spec card I have above.
Thanks fellas.
Old 02-21-2008, 10:00 PM
  #34
DezertRacer's Avatar
This past weekend from Primm Valley, NV
http://www.youtube.com/watch?v=QPV_O2K7bNY
Looking for a cam suggestion for the LQ4.
Old 02-21-2008, 10:17 PM
  #35
LS1 Tech Veteran
Steve Bryant's Avatar
I don't know what you're looking for beyond the suggestions that you've gotten thus far. However, I can tell you that my cam is excellent from off idle through about 4,800 RPMs. A great cam for a very heavy truck (6,700 pounds) that occasionally tows a heavy trailer (8,600 pounds).
Old 02-22-2008, 07:21 AM
  #36
zippy's Avatar
I would shy away from the Rhodes lifters for a Gen III. Unless you have an adjustable valvetrain they won't work. I know this from first hand experience.
Old 09-26-2008, 07:21 AM
  #37
jeepnfool's Avatar
Hey guys, I just read this thread and have a few questions. I am about to drop a 04 LQ4 with a 4L80E into my jeep wrangler rockcrawler/daily driver and was wanting to know a few things:
1. Besides a tune, what could I do to get some more HP w/o doing heads, I was thinking a cam, but dont know which one?
I will be running 40-42" tires with 5.29 gears and wont see hi revs, I will need most of my power in the lower rpm ranges for crawling....
Old 09-26-2008, 08:06 AM
  #38
nonnieselman's Avatar
Thats the one Inchup has.. it should help you out. also you know first gear is alot taller in the 80E..
If you could do some headers in your Jeep, that would help.
A tune will help you out a Ton!!
CompCams XR259 206/212, .515/.522, 112LSA
Old 09-26-2008, 10:10 AM
  #39
jeepnfool's Avatar
Its is deffinately getting a tune and headers...its a complete custom build.....If I put that cam in it, will I need to do anything else to it? Sry...I am new to these....
Old 09-26-2008, 10:39 AM
  #40
jeepnfool's Avatar
Also been reading and found where someone mentioned a 01 LS6 cam...What would be the good and the bad of using that instead of the XR259?
Quick Reply: All low end LQ4 cam suggestions?
