another cam question
just looking for some quick info.... is this going to be a good enough cam for 05 Z71 5.3 ecsb with a 9.5 FTS lift kit on 37 13.50r22
Cam Style Hydraulic roller tappet
Basic Operating RPM Range 1,200-6,000
Intake Duration at 050 inch Lift 212
Exhaust Duration at 050 inch Lift 218
Duration at 050 inch Lift 212 int./218 exh.
Advertised Intake Duration 265
Advertised Exhaust Duration 271
Advertised Duration 265 int./271 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.522 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.529 in.
Valve Lift with Factory Rocker Arm Ratio 0.522 int./0.529 exh.
Lobe Separation (degrees) 114
Computer-Controlled Compatible No
Grind Number LS1 XR265HR-14
The best recommendation I can make is telling you to call Yank & talk to Dave for a few minutes, and call Circle-D & talk to Chris for a few minutes. You'll have all the information you need at that point.
I just put a TSP220 112lsa cam in my truck last week and was expecting to lose a lot down low with the stock converter till my circle d 3200 shows up but it still has a lot down low and puts u back really well once the rpms get up. I am on 36" Iroks right now.
The cam ur looking at would work really well too, I thought about getting it but got a good deal on this one.
The 112 LSA helps move the powerband back down just a bit.
