another cam question. Need help with a cam for a 418
Old 03-16-2008, 04:58 PM
Dark Halo's Avatar
what do you think about this cam
****Vengeance Racing Vindicator Camshaft****
240/244 .605/.596 112 LSA. 2400-7000 Rpm Power Band
shows very good power increase on stock heads. Maybe I will get a custom grind with same duration but increase the lift a little. I will be using cnc'd heads with large valves.
Old 03-16-2008, 08:08 PM
LS1Tech Sponsor
Slowhawk's Avatar
You need someone to pick a Cam for you to match the cubic inch,heads,exhaust and intake setup.Off the shelf will work but not ideal.
Old 03-16-2008, 09:47 PM
Dark Halo's Avatar
yea im not a cam guy by any means, so I am open for any ideas. I had thought about using the heads I have but I think I want to get bigger valves and larger runners this go around. I have considered L92 ported heads on the new set up.
2500ZL1
01-25-2016 06:30 AM
chvy=power
08-31-2015 10:51 AM
lawhitediamante
08-12-2015 12:14 PM
WICK3DxGATA
07-21-2015 06:59 PM
Quick Reply: another cam question. Need help with a cam for a 418
