Another Great LSX Tool from JPA LOOK INSIDE
Old 04-10-2007, 04:50 PM
blownerator
BlownChevy's Avatar
Default Another Great LSX Tool from JPA LOOK INSIDE
FIRST EVER LSX Crank Pinning kits from JPA!
Crank Pinning Kits will be available next week! High quality CNC machined steel jigs along with all the necessary drills and reamers to complete the job with confidence! The kit will include detailed instructions of the process so even the shadiest of shade tree mechanics can get the job done right! Included in the kit will be one brand new GM Balancer Bolt.
This modification is mandatory for all high revving and Supercharged LSX motors.
This is not a re-packaged kit from the "other" manufacturer, this is all new and the high quality you would expect for over 10% less!
$75.95 in the lower 48. UPS ground!
Old 04-10-2007, 05:08 PM
ZR1 DREAMING's Avatar
You're the man Brian!
How beneficial is this for someone with an N/A high compression engine... let's say lower gear shift points go at 6800? I can see the supercharged engines requiring it, but haven't heard any stories on th N/A side.
Old 04-10-2007, 05:10 PM
blownerator
BlownChevy's Avatar
I have seen a few N/A cars loose their balancer, you are correct it is few and far between.....But hey, cheap insurance IMHO
Old 04-10-2007, 05:15 PM
Gotchya. And agreed, that would suck!
Old 04-10-2007, 06:54 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Ya'll need to make that tool like Kent moore makes that holds the flywheel while you tighten the crank bolt, that is a sweet tool to have.
Old 04-10-2007, 07:00 PM
blownerator
BlownChevy's Avatar
working on that as we speak
Old 04-10-2007, 07:39 PM
1slow01Z71's Avatar
Would you mind sending me a PM of what ya'll may be working on tool wise, I was planning on buying the kent moore set fairly soon but I may hold off if you are making the main stuff I want then Ill wait, sounds like ya'll are going to be making some good stuff
Old 04-10-2007, 10:48 PM
Lurius's Avatar
I may have to get the JPA Gen III tool kit instead lol.
-Lurius
Old 04-10-2007, 10:53 PM
Restricted User
crazykid's Avatar
Procharger has had this tool for a long time
Old 04-11-2007, 09:08 AM
blownerator
BlownChevy's Avatar
Cool, glad to hear that!
Quick Reply: Another Great LSX Tool from JPA LOOK INSIDE
