Any suggestions on what size cam i should get?
1 Post
I'm currently looking at this for my 4.8, i'm not an expert though, so i could be WAY off.
http://www.compcams.com/Cam_Specs/Ca...csid=1085&sb=2
I have a gauge for that
The tr220 is very popular with a stall around that size. It may be a bit large for a 4.8, but I think it would be fine. The comp 212/218 posted above is also very popular, although you could probably go bigger with the 3200 stall.
Oh and take off the tb spacer and hypertech, sell both, and get a tune from one of the vendors on the right.
yeah ive been trying to sell the hypertech for awhile now around here locally but havent had anyone interested. alright i will def look into both of those cams. should i build around the cam as well, lifters springs? appreciate it. which tune would you prefer? ive heard good things about nelson.
I have hptuners so I do my own, but I always hear good things about blackbear and wheatley. Nelson is good from what I hear, but is a bit more expensive so not as many go with him.
LS6 springs would be fine with the 212/218 since it is relatively low lift, and it should work fine with the stock converter, although a bigger one (2600-3000) wouldnt hurt.
