Any way to tell what rpm range your engine is most efficient in?(mpg talk)
Originally Posted by TBSS
Please tell me you're not going to try 4.10's in a 10-bolt with 37" tires... ![Bomb](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_bomb.gif)
![Winky](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_wink.gif)
![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
Nope I have a 14 bolt SF sitting in the garage with a detroit locker, arp stud kit, aftermarket alloy axles, and a t/a diff cover waiting to go in as soon as I get the engine running, come on now Im not that retard
![Secret2](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/secret.gif)
The 418 will build the low end torque period, no matter the cam....to an extent of course. Get the tire size you want and drive what you've got. Log and tune and decide on gear last. With a couple months of driving and tuning to decide. Everything is different. Don't decide on gear now. Let it be a finishing touch when you are "done".
![The Judge](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_judge.gif)
Problem is, I have all the parts to rebuild the 14 bolt right now last thing to buy is the gears, so it would be nice to buy the gears, once, I can run it on the 10 bolt for sure and be easy on it but after its up and running thats the next mod is the rear. I also bought the front diff off turboberserker which has 4.10s in it so I would like to know if I could get away with that since r&r of the front diff isnt exactly fun. Thats why im trying to get some suggestions for where I should be so I dont have to "trial & error" it. The 14 bolt I have came with 4.10s that are in good shape so Im going to start off with the 4.1 ratio and see if I happy, main thing I was worried about was having to go with 4.56s.
