Anyone know anything about this cam.
SPAM HUNTER
A buddy of mine pulled it out of a LS1 GTO at his work.
Numbers on it are as follows
3725R/3655r
HR116 +4
J1954-06
This is all i know, any help would be appreciated.
Dustin
3725R/3655r
HR116 +4
J1954-06
Dustin
PT's Slowest Truck
The first numbers look like Comp numbers, but the HR116 is something that I've seen on Crane's site which stands for "Hydraulic Roller, 116 LSA", and the +4 should be 4* of advance ground in. Maybe try punching the top numbers into some cam manufacturer's sites and see if anything comes up...
SPAM HUNTER
I guess this is what it is, according to SStroker on tech
Comp Hydraulic roller:
Intake is 230° @ .050 .592 lift (1.7), XER lobes. "most aggressive hydraulic roller profile to date"
Exhaust is 244° @ .050 .595 lift (1.7)Xtreme RPM high lift lobes.
LSA is 116° with 4° advance ground in.
Dustin
Dustin
SPAM HUNTER
I agree with that. My buddy said when you first started the car it would barely run, but after about 2-3 minutes it would just clean up and he questioned it had a cam at all. Also that was in a ls1 short block with ported 243's and a fast intake.
Dustin
Dustin
no title here
I bet that cam would be mighty quiet on a 116 LSA. I would think you would need some healthy gear and converter. Just a guess, I bet it would run awesome. But the LS1 didn't have more compression than 10.5 so why would the 6.0 need more? Wouldn't that cam be slightly more tame in a 6.0 vs a 5.7 because of the added displacement?
SPAM HUNTER
You only gaining a little though, Im going to talk to some people and get some opinions, Cam swaps are a pain (not really) but why do something to save money you know what i mean?
Dustin
Dustin
PT's Slowest Truck
Dustin
Dustin
But then again, I could be totally wrong
Rick
