arp head stud torque specs
Baltimore Whore
http://www.ls1howto.com/index.php?article=2 towards the bottom of the page youll see it
Or https://www.performancetrucks.net/fo...ecs+head+bolts
John
John
Former Vendor
I just had my AFR 225 heads installed along with ARP studs and I think it was 25 ft/lbs for the shorter(8mm) and 75 for the longer(11mm). But it depends on weather you use their lube or 30 weight oil.
thanks for the links and info guys, but in the three links it refers to arp head bolts I am lloking for the spec on studs, if anyone has the specs for the head studs that would be great,. thanks
