Bad Head Gaskets
Old 09-08-2009, 09:10 PM
  #31
Registered User
kybray44's Avatar
After looking up some part numbers, it appears there are two different types of gaskets made...how would I tell what type I have before teardown? Thanks
Also how would I tell what size head bolts I need?
Old 09-09-2009, 07:42 AM
  #32
03 BLACKOUTSSS's Avatar
As for the size of the head bolts, there was a break in the years, where they went from long and short bolts, to all long bolts, or something like that. Jon @ Texas Speed was very helpful to me in that respect when I did my swap.
The gaskets??? Can you post some links to the two that you have found, so we can look at them?
Old 09-09-2009, 09:07 AM
  #33
chevrolet all the way's Avatar
If its never overheated, what is the likelihood that the heads will need to be resurfaced?
mine never overheated when it blew on the interstate at 1/4 throttle and warpped 4 thousandths. it is very possible. if you are ready to pay $1700 then just buy some new heads not worry about machining and go for it
Old 09-09-2009, 09:53 AM
  #34
Custm2500's Rude Friend
1FastBrick's Avatar
General rule of thumb is... ( there is always an exception to every rule so consider it a basic guide to go by. When in doubt pull your old part before you make the purchase and seek proffisional help matching up the old part )
Look around the edges of the head surface for the gasket material you should be able to tell what you have by scratching at it.
Its either a fiber materail or a metal gasket.
99-02 was a graphite/fiberstyle gasket - #12457116 -4.8L/5.3L GM Graphite Gasket
03-up is a MLS head gasket - #12575329 -4.8L/5.3L GM MLS Head Gasket
#89017252 - 5.3L/4.8L Complete Head gasket kit containg all gaskets need to R and R the heads.
99-03 head bolts long and short - #12498545
04-up was the change to all same size - #17800568
https://www.performancetrucks.net/fo...M+part+numbers
Last edited by 1FastBrick; 09-09-2009 at 08:40 PM. Reason: Apparently Im wrong so I edited the info
Old 09-09-2009, 11:07 AM
  #35
PT's Slowest Truck
budhayes3's Avatar
General rule of thumb is... ( there is always an exception to every rule so consider it a basic guide to go by. When in doubt pull your old part before buying and seek proffisional help matching up the old part )
99-00 was a graphite/fiberstyle gasket - dont have a part number.
01-up is a MLS head gasket - #12575329 -4.8L/5.3L GM MLS Head Gasket
Does the long and short bolts apply to the LQ9 6.0 also? (I believe it does but I want to be sure )
Old 09-09-2009, 03:20 PM
  #36
Registered User
kybray44's Avatar
How would I tell if I have positive or top hat designed stem seals?
Old 09-09-2009, 03:25 PM
  #37
Registered User
kybray44's Avatar
12575329 when I use this to look up, its say 03+
12457116 is the part my local gm dealer quoted me and it says 99-02
Old 09-09-2009, 07:57 PM
  #38
1FastBrick's Avatar
An LQ9 is No different
The only thing that makes an Lq9 any different is that it has flat top pistons instead of the dish ones found in the Lq4. After 05 the all got the same rods...
Old 09-09-2009, 08:04 PM
  #39
1FastBrick's Avatar
Intresting I have a 5.3 that I pulled from an 01 or 02 Tahoe that had MLS gaskets.... Well, I guess you will have to pull the head and see...
AT the corner of the head were it's rounded, some of the material hangs out. Scratch at it and see what you have...
Old 09-09-2009, 08:34 PM
  #40
PT's Slowest Truck
budhayes3's Avatar
Thanks man...I sent you a PM btw...
Quick Reply: Bad Head Gaskets
