best 4.8 cam??!!
Old 05-06-2006 | 07:24 PM
superfox's Avatar
Default best 4.8 cam??!!
hi all am now on this forum,
what the best 4.8 auto trans parts like camshaft springs retainers, now my car stock only k&n filter ,i have $1000 what the good think to run ,someone tell me to run LS6 2002 Z06 Camshaft with comp 26918 springs & comp titanum retainers ,but its expensive he tell me to go with Patriot Performance spring kit are the kit good ?
Old 05-06-2006 | 07:49 PM
tarinitup's Avatar
9 Second Truck Club
cams are expensive i just spent 610 bucks for the install, 200 for 918 springs, 100 for pushrods, and 200 for a used 224/224 cam.
Old 05-06-2006 | 08:16 PM
ONLYA4.8L's Avatar
Wow.. look on ebay... Spring cost like $130 on there and you can find a cam on here in parts for sale pretty cheap.. I heard the LS6 cam is good but.. for all that work I'd rather go with something better.. You have to base your other mods around the cam...
Old 05-06-2006 | 09:41 PM
dirtyratt's Avatar
Lingenfelter GT2-3 is a good one for the 4.8 i have it in my 5.3 i was very impressed you can get the cam and ls6 spring for under 450.00 ------Camshaft specifications: 207/220 573/.580 w 1.7 rocker 118.5 CL. Kit includes GM LS6 valve springs #12586484 which use the stock factory LS1 valve spring retainer. Camshafts ground by Competition Cams for Lingenfelter.
Old 05-06-2006 | 10:10 PM
PappyDan's Avatar
Tribe Shaman
lets start with first question.
1. will you be doing the work or will you be paying someone to do the work.
the LS6 springs are good for a lift of .570 and can cover the lift of most of the cams available for our motors, any thing over .570 and you will need the comp 918.
often someone will put a cam up for sale in the classified section that you may be looking for.
a good start for a 4.8 would be
LS6 springs
GM camshaft 12560950 with a lift of 525 / 525 on a lsa of 116
a TB stall
cold air intake
shorty or long tube headers depends on emissions in your area
duel exhaust
and a custom tune on the pcm.
now if you go shopping in the right places you can pick up almost all of this stuff for about
a 1000.00 and you will notice a very nice gain in horse power and torque with a much better top end.
Old 05-07-2006 | 12:31 AM
reveille5's Avatar
Not to mention you will need a tune.
Old 05-07-2006 | 07:27 PM
superfox's Avatar
LS6 springs
a TB stall
cold air intake
duel exhaust
what the good headers ?
i have K&N filter are they good or not in my car , where good place to buy LS6 cam springs chep way
Old 05-07-2006 | 10:36 PM
PappyDan's Avatar
Tribe Shaman
good headers would be a set of long tubes.
a K&N works great in a truck but I see you wrote that you have a car, it works in a car too.
check out the sponsors over to the right for a set of springs, now if they do not have
what your looking for the you could check out summit, e bay, or the classified section here on the board.
Dan Neumann
11
08-07-2022 10:06 AM
JordanH
08-08-2015 08:59 PM
Castro45
24
07-31-2015 08:13 PM
Suburban2500
07-19-2015 05:50 PM
06 4.8
07-15-2015 08:17 PM
