Big Block Chevy carnage
Old 07-13-2011 | 08:12 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Default Big Block Chevy carnage
Pulled this engine out of a 66 Corvette to freshen it up. Ran pretty good, but was leaking from almost every gasket. Noticed it was leaking from the rear cam plug, and and had bearing babbit in the oil pan, so I decided to tear it down. Thought I'd share some pics.
#7 piston & rod:
#7 cylinder wall:
Old 07-13-2011 | 08:59 PM
Beatdown Z's Avatar
Laid Back
Damn that's rough. Going to need a sleeve or find another block?
Better yet, just do a big cube LSX swap!
Old 07-13-2011 | 09:14 PM
dirt track racer 81's Avatar
Wow never seen a rod split like that..
Old 07-13-2011 | 09:22 PM
The rod let go of the pin. The pin is still in one piece, just floats back & forth between sides of the cylinder wall.
Old 07-13-2011 | 09:25 PM
Waiting for the vehicle owner to make a decision. This is a '68 396. I'd like him to tell me to put a '66 427 back in the car(like it should have).
Old 07-14-2011 | 04:40 AM
rjwz28's Avatar
Man Motor club
So tell him
Old 07-14-2011 | 11:09 PM
budhayes3's Avatar
PT's Slowest Truck
I was going to ask if that was a 427, and assumed that it was since it's in a 66 Vette...gotta talk the fellow into putting the correct mill in there. Even if the numbers don't match, at least it will be as it should
That 396 is looking pretty ugly...is it even worth the coin to try to sleeve and salvage?
mikeyjm1
17
10-30-2015 12:04 AM
Pontiac Derek
09-19-2015 02:49 PM
MA$TER_E
09-09-2015 04:14 PM
USMCvet0311
09-04-2015 10:43 PM
Alco
09-04-2015 05:08 PM
