biggest cam for stock stall
Old 02-02-2007 | 09:39 AM
LARRY01Z28's Avatar
so no higher then a 2600. thanks everybody
Old 02-02-2007 | 10:01 AM
moregrip's Avatar
what a rush!
the stock HD converter should brake and flash stall to about 2500rpm, no need for a converter with a small cam.
Old 02-02-2007 | 10:26 AM
dirt track racer 81's Avatar
weve put a comp 212 218 low lift version in an HD, the guy says he tows alot with it and said he needed a torque cam, so we put that cam in and the guy says he loves it, said its great on towing
Old 02-02-2007 | 10:34 AM
LARRY01Z28's Avatar
ok cool. great info guys. Larry
Old 02-12-2007 | 04:54 AM
Slowhawk's Avatar
LS1Tech Sponsor
FYI-I run a 216 Cam on my 5.3L with stock converter.No problems at all.Still idles at 600rpm with no surging or stalling.I'm thinking an aggressive 220 Cam would work too.
Old 02-12-2007 | 02:25 PM
12secSS's Avatar
When talking about towing, it is very different from N/A and no towing. While towing, depending on the size of the trailer, you do not want slippage from the trans, as this causes extreme heat. Stick to a stock stall, but opt for a multi-disc unit. This will help pull the trailer at low speeds (like from a stop light) and will not cause excessive slippage during shifts on the clutches/bands. With the multi-disc it will provide better holding capacity once the TCC is locked up, so unlocking the TCC will not be much of a requirement. You will only need to downshift, but can maintain the TCC locked.
As for cam choice, I would go no bigger then a 218-220. Try to get as much lift as possible though. Remember, while towing, you are not going to want to be at 4000-6000 rpms all the time. You will want to be around idle-3000 rpms for best towing. Good luck!
By the way, I have the low lift 212/218 cam, with Pacesetter LTs and I tow a 11,500 lbs (total, fully loaded) enclosed trailer. This almost the biggest I would go (cam duration wise).
5.3Okasai
03-09-2022 02:07 PM
ARC
57
02-21-2022 11:54 AM
Castro45
24
07-31-2015 08:13 PM
Matt331
07-26-2015 10:40 PM
therock
07-25-2015 10:23 AM
