Biggest displacement potential?
I know plenty about GM engines and their displacement potential, but I'd like to learn more about Ford and Dodge engines.
1. What is the max cubic inch that a Ford 5.4L block can be worked to?
2. Same question, but for the Dodge Hemi.
3. Are any companies resleeving Ford or Dodge blocks for more bore dia?
4. Any off-the-shelf stroker kits for Dodge or Ford yet?
For those that would like to know about the GM engines:
The LS1 based engines have seen up to 455ci with a resleeved block and 4.25" stroker crank. Thats the biggest I have heard of so far. Most strokers are stock bore (4.00") 6.0L blocks with 4.00" stroker cranks, which makes approximately 408ci with a slight cleanup bore. There are quite a few resleeved 427ci GM engines with a 4.00" stroke.
Tony
Tony
Originally Posted by rtspeeddemon
Its common for a lot of us R/T owners to stroke out our 5.9 (360) to a 408. Failrly simple and Eagle makes a nice drop in steel crank.
There are cams, and I think they're just on the edge with getting custom computer tweaks to make the cams work. There are turbo kits and supercharger kits for the hemi out there right now though.
The new 6.1 liter Hemi with a few mods should lay down some good smack all by itself though.
10 Second Truck Club
Originally Posted by Nine Ball
Thats good to know. What is the bore diameter on the 5.9L engine? 4.00"?
Stock Stroke 3.580
Rod Length 6.125
K.J
Originally Posted by 02sierraz71_5.3
very expensive
