bore 5.3 block
Old 10-21-2009 | 04:38 PM
05gmc's Avatar
Default bore 5.3 block
can you make a 5.3 into a 5.7 with a .060 bore job
Old 10-21-2009 | 04:42 PM
LowBlack99's Avatar
You can make it a 5.7, not sure the exact overbore. It's been done many times, try searching with the hand search function above.
Old 10-21-2009 | 04:47 PM
ForcedTQ's Avatar
Lightbulb
A 5.7L bore is stock @ 3.898". A 5.3L bore is stock @ 3.780. It would require a .118" over bore to fit stock 5.7L pistons in a 5.3L block. It has been done many times, just need to have the block bores checked to ensure you won't end up going through, or having the cylinder walls end up to thin.
Old 10-23-2009 | 04:47 PM
Sales2@Texas-speed's Avatar
FormerVendor
^^ Well said!
Old 10-23-2009 | 05:06 PM
jacobbanner's Avatar
i know im not a high posting kind of guy in here, boring it wat make it a 5.7.. strokeing it would
Old 10-23-2009 | 05:43 PM
PedaltoMetal's Avatar
5.3's and 5.7's have the same stroke 3.622
Old 10-23-2009 | 05:57 PM
ForcedTQ's Avatar
Thumbs up
Exactly, a 4" stroke with a 3.905" bore (overbore LS1 pistons) equates to a roughly 383.25 cubic inch displacement engine.
A 4" stroke with a 3.898" bore (stock LS1 bore) equates to a roughly 381.87 cubic inch displacement engine.
If you are thinking about keeping the stock bore and going with a stroker crankshaft, you can do that too now courtesy of Wiseco! Just for reference a 4" stroke with a 3.780" bore equates to a roughly 359.10 cubic inch displacement engine. If you choose to go this route be sure and get "Good" cylinder head work done, as the bore limits the size of your valves in the head. That makes bowl / valve seat blending, throat blending, and valve job that much more important. This would be a strong tourquey bastard of an engine, a combination that I'm actually thinking about building for my truck!
Old 10-23-2009 | 06:17 PM
If you go with a new crank why not go 4.125 and bore 3.905 = 395cid
I may change my build plans now that I think about it.
Old 10-23-2009 | 06:45 PM
stock48's Avatar
9 Second Truck Club
Sonic, sonic, Sonic! All blocks are different
Old 10-23-2009 | 07:01 PM
00_Hotrod's Avatar
I was planning to do a iron 5.7 until i heard of all the problems people have has w/ the boreing, now i have second thoughts....
