Bore a 5.3L block out to 5.7L?
Man, I didn't know it was that reasonable, I was thinking in the $300-$400 range. It might not be such a slow build-up after all. I need to make some calls around Houston and get some prices.
I was thinking:
3.893 bore (LS1)
stock 5.3/6.0 crank
Scoggin Dickeys forged LS6 pistons
Lunati H-beam rods or stock LS6
stock LS6 or Patriot LS6 heads
stock truck intake
TR 220 cam
stock LS6 Maf
stock ETC tb
I was thinking:
3.893 bore (LS1)
stock 5.3/6.0 crank
stock truck intake
TR 220 cam
stock LS6 Maf
stock ETC tb
FormerVendor
Originally Posted by Element 80
I was just looking at your site and will the LM7 stage 2 heads be good for my plans? How much do they run for a pair and w/ no cores?
Richard
I think I'll go w/ a 3.90, 10.5:1 would be nice. I plan on going N/A. Thanks a bunch for your help, hopefully I can get some $ saved for the heads. One more ? though, would those heads work ok on my stock 5.3?
FormerVendor
The high compression will help the torque across the band. I recommend caution with higher c/r in an extended cab truck. The hot summer temps and higher loads of the truck chassis can cause a fair amount of knock with pump gas, although I believe you have 93 octane pump gas in your state. We have 91 octane here and it makes engines with high compression ratios knock under high load situations.
We install a 2.02" intake valve on our Stage 2 heads. That's VERY close to the cylinder bore. I wouldn't want to say for sure it would be ok because of the close valve/bore clearance. Also, the intake port runners are a bit large for a 5.3l displacement engine. I wouldn't recommend those heads be used on the 5.3l. I don't want to sound like doom and gloom, but I believe it would be better to wait to do the heads at the same time you build the engine.
Richard
Richard
