Break in oil????
the cylinder walls act as a light sand paper to seat the rings (take the high spots off of the rings. without putting a load on the rings you're just polishing the cylinder wall and your rings arent getting seated correctly. the only way to fix that is to pull the motor apart and rehone the cylinder to rough it up.
