builders, machinist, shit someone with answers?
I have a gauge for that
Where are you?
You dont have to do timing chain and oil pump, or even hardened pushrods depending on how aggresive your cam is and how high you want to spin it. Although all of those are good upgrades, they arent mandatory. You need the cam and springs for sure, but you may even be able to reuse your stock gaskets.
Where are you?
You dont have to do timing chain and oil pump, or even hardened pushrods depending on how aggressive your cam is and how high you want to spin it. Although all of those are good upgrades, they arent mandatory. You need the cam and springs for sure, but you may even be able to reuse your stock gaskets.
The cam is a Voodoo 217/233 on a 113 with .54 lift. What all do you think will support this cam?
great answer. Im located in NC/SC boarder. Pretty much can drive anywhere in those states. That was exactly what I was trying to find out. Im going to do the chain as its chap. Going to be looking for some springs, and hardened pushrods.
i mean all the parts on the list is needed then
PAC Single Beehive Valve Springs good to .600 lift: $149.99
Set of Hardened Pushrods: $99.99
LS2 Timing Chain: $37.99
Ported/Blueprinted LS6 oil pump: $139.99
Complete Camswap Gasket Kit: $49.99
Im not going to get the driveshaft right now. So with my cam that totals 864$ the shops labor is 880$ So the cost to do my cam swap professional is 1728$ hmmm. For what its worth I can do a 6.2 swap. lol
lukn4trbl355
10-21-2015 11:19 PM
