Building a 408, need opinions on setup
#21
HKE in Houston, built the fastest LS1 and LT1 in the WORLD... both with eagle crank and rods. Not to mention David Wolfe fastest Drag Radial car in the world, Eagle internals also.
#23
I don't think it is a question of the strenght of eagle products, I personally ran eagle h beam rods for about 30,000 high boost supercharged miles without any problems. I think the eagle products require more machine work to get them into specs. An eagle crank will hold up to whatever you throw at it, thier products just require a little more work by the machine shop to balance the rotating assembly.
#24
ive never heard anything bad about eagle products anyway, so until i do im not gona talk about them, just my opinion, im probably gona end up with an eagle crank or either callies, i think both brands are good
#25
Hey Derek, don't you run into issues when milling the 317's too much? I can't find the thread from what I'm referring to. Anyways, sounds like a good build and don't be afraid to use Eagle's products either.
#26
that is EASILY the worst information ever posted on any internet forum EVER. Eagle has powered some of the quickest/fastest LSX cars to EVER be assembled. Fereday was the first LSX in the 7s and was running a 3 year old Eagle internal'd motor. Eagle is good ****, its more about choosing a builder that's worth a **** and can build what you need.
