Bumping up Compression Questions???
Are there any differences between 862 and 706 heads besides the notch? Do 706s flow slightly better? why did GM change the casting # if there the same head? Which heads would you buy?
If I buy 862 heads and they have the notch, how much milling is needed to remove the notch? If I can be removed!
I run 87 octane with all boltons dyno tuned
If no notch I plan on milling the heads .01 and getting .04 cosmetic gaskets
COMPRESSION
stock 9.5
.01 milled 9.7
.04 cosmetic 9.96
.035 cosmetic 10.05
I know more compression and low grade 87 will mean timing will have to be reduced. So how would 9.7 compression run with 87 tune? If I go with cosmetic gaskets I will run 93 octane tune even know I dont want to add another $5-10 on top of $70-80 it cost to fill up now.
What would yall do?
COMPRESSION
stock 9.5
.01 milled 9.7
.04 cosmetic 9.96
.035 cosmetic 10.05
What would yall do?
706's were out from the beginning. Not all the 706 castings are bad. 706's were used all the way up till 2007 Classic. I bought an 4.8 with 706 heads that came from an 07 Classic.
The heads were cast using a different casting process. The 706 has a more consistent casting with less core shift. Once you start porting them there really no different.
If your looking to have work done, I would get a set from one of our sponsors. Both SDPC and WCCH have ported 5.3L heads starting at $899.
Hell the last set of heads I had redone cost me $300 in machine work and I supplied all the parts. If you price in the parts these guys use, Like new valves, springs, and seals, the porting is so cheap why not spend the money...
Got a set of 862s with no notch last night for $80 with 55K on them
I'm a broke college kid that's why I can afford to get them professionally cnc
I plan on taking out the rocker lumps and blending with 140 grit. Take a lil of the exhaust side but not much
What do yall pay for milling? I dont have money for a valve job so I'm going to just lap them. They already come 3 angle from factory.
MA$TER_E
09-09-2015 03:14 PM
SWINGRRRR
09-03-2015 07:49 PM
