Cam
Old 01-15-2016 | 01:45 PM
Dbar72's Avatar
Registered User
Default Cam
I need some help rebuilding my 2002 1500HD 6.0L. I'm getting my heads ported and polished, shorty headers, cold air intake, new coil packs along with new wires. I'm wanting a cam something to sound good and can tell I have one. Can anyone help me with this? I get lost with choosing cams
Old 01-15-2016 | 01:53 PM
FFDP's Avatar
I'd skip the shortys and go long tubes. Shortys aren't worth the money to me.
And do you want to keep the factory stall with this cam?
Old 01-15-2016 | 02:08 PM
Dbar72's Avatar
Registered User
I'll get long tubes then. Im gonna be daily driving it so I don't know if I need a after market stall? Is this something I need instead of factory stall?
Old 01-15-2016 | 03:47 PM
gamble686's Avatar
Circle D has some great options for something that will fit all your needs. I would recommend something like a 222/226 if you get a stall. If you stay factory I would go more mild like a 216/220
Old 01-15-2016 | 04:56 PM
Dbar72's Avatar
Registered User
Converter Diameter: 278mm - 11"
Stall speeds 2600 to 3200 RPM
Hand TIG Welded
High Carbon Spun Wound Lock-Up Clutch Lining
Heavy Duty Torrington Bearings
Exclusive CDS Bearing Retainer
LS Bolt Pattern
Old 01-15-2016 | 04:57 PM
Dbar72's Avatar
Registered User
Is something like this I would use to get a better stall?
Old 01-15-2016 | 06:21 PM
Dbar72's Avatar
Registered User
Hand TIG Welded
LS Bolt Pattern
Is this what I need to have a good stall? Will it be good for everyday driving?
Old 01-15-2016 | 07:19 PM
Dbar72's Avatar
Registered User
273/279 .581 hydraulic roller by comp. is that something I can run?
BLOWN 364
01-29-2016 10:31 AM
travieso
01-02-2016 04:18 PM
Blwn99x
12-26-2015 01:10 PM
mikeyjm1
14
12-21-2015 03:22 PM
bradley753
12-18-2015 09:22 PM
Quick Reply: Cam
