cam experts (or not) come in
Old 09-20-2006, 07:17 AM
TURBHOE's Avatar
Default cam experts (or not) come in
would you run this cam? sorry for the crappy pictures. the hassy looking stuff on it is just oil where i lubed it up to keep from corrosion. is this pitting bad enough not to run or what?
Old 09-20-2006, 07:27 AM
2nd fastest 5.3 ECSB
trever1t's Avatar
I am no expert but I don't think it should have that kind of wear?
Old 09-20-2006, 07:44 AM
KySilverado's Avatar
I would not put that cam in my engine.
Old 09-20-2006, 07:46 AM
when i took my stock cam out after 70k miles it didnt look like that and when i took the vette cam out after 12000 miles it didnt look like that either....i wouldnt use it
Old 09-20-2006, 08:24 AM
Nick™'s Avatar
somethings wrong with that cam, I wouldn't touch it - I've seen a 100,000 mile cam that looked near mint, you shouldn't be seeing wear and pitting like that
Old 09-20-2006, 09:10 AM
RabidStreetRacer's Avatar
I would take it to a shop to get regrounded.
Old 09-20-2006, 01:08 PM
VortecHOjunkie's Avatar
If you have it reground you will change the cam specs on that lobe. You could have all of them done but unless it was free, you would probably be better off with another cam. If it is just a lobe or two messed up, I would say it was probably a problem with the lifter, probably the bearings going bad in the roller, since I am assuming this is a roller cam.
Old 09-20-2006, 03:13 PM
Baltimore Whore
Mangled03gmc's Avatar
Nope I wouldn't be putting that hunk in my engine..
Old 09-20-2006, 05:39 PM
Okie5.3's Avatar
no. yes its bad enough not to run.
Old 09-20-2006, 08:09 PM
TURBHOE's Avatar
ok not going to use the cam. its a used mti c2 cam.
Quick Reply: cam experts (or not) come in
