cam install is done, but i hv a few questions
Old 07-03-2009, 02:39 PM
Default cam install is done, but i hv a few questions
well im finally done!! engine fired right up, oil psi good, i have a SES light, im assumming it probably throwing a misfire code( saya thats common on ls1howto), and she dont like to idle. How long will it take to learn its idle? ita a DBW, im going to see wheatley monday, but wanted to know if there is anyway to get it to idle on its own
Old 07-03-2009, 03:12 PM
anyone??
Old 07-03-2009, 03:25 PM
sonoma43's Avatar
you can un-plug the battery for a few minutes and then plug it back in and let it re-learn the idle but I doubt if it will help much. May just have to drive with 2 feet for a few days.
Fastest D1 Procharged Truck
02_Orange_D1SC's Avatar
how big is your cam anyways? just two foot it till you get it tuned by wheatley
Old 07-03-2009, 03:42 PM
its just a copy of a 2002 ls6 cam-204/218 .550 .550 but ground on a 114lsa.
Old 07-03-2009, 03:50 PM
isnt that big then should idle half *** just give it a day or two should straightin itself out at least so you can drive it to get it tuned
Old 07-03-2009, 05:08 PM
BigMikeGXP's Avatar
yeah it will be decent after a couple days.
Old 07-03-2009, 06:19 PM
emialed charlie about monday, he emailed me back w/ a little tip, if u unplug the back drivers side pcv valve off the valve cover, it helps it idle. and sure as **** the SOB is idleing!!! Once again, Wheatley is the man
Old 07-03-2009, 06:38 PM
Truck Sponsor
Wheatley's Avatar
Glad it Worked Kasey
See ya monday buddy
Wheatley
Old 07-03-2009, 06:52 PM
emialed charlie about monday, he emailed me back w/ a little tip, if u unplug the back drivers side pcv valve off the valve cover, it helps it idle. and sure as **** the SOB is idleing!!! Once again, Wheatlety is the man
no **** thats some good advice there
Quick Reply: cam install is done, but i hv a few questions
