Cam specs on an 06 5.3L?
Ok guys, i just bought me an 06 silverado and it feels quite a bit stronger than all the older 5.3's i've had and drivin. I know they got electric fans but what else did they change? I know the specs on some of the older 5.3's but what is it on an 06?
Valves - Valve Lift - Intake
11.6 mm
0.457 in
Valves - Valve Lift - Exhaust
11.85 mm
0.466 in
this for 2005 LM7 5.3L give me the pro code for you current engine and will post to you
2005 and 2006 r the same diffrence started from 2007 where the lift increased to 480
11.6 mm
0.457 in
11.85 mm
0.466 in
L59 = flex fuel, so the fuel injectors are bigger. E-fans, too, as you've already pointed out. Is it possible your '06 has a lower gear ratio (higher numerical value) like a 4.10?
