Cam specs and pics of t/ Lunati cam for my 418 paging SportSide lol
#22
You are right. I disagree about a huge part. I would say that lobe profile, or the shape of the arch play a small role when you are talking about a certain type of cam. Basically the minimal they can change the profile on a hydraulic roller is not worth the money. If you are competing in a ruled class I may see the purpose.
If you are really worried about it, then go solid roller where the lobe profile can be much more agressive. We are primarily talking about every day street engines here thus that is why the lifters are hydraulic.
I'm still not giving $400 for a cam.
![The Judge](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_judge.gif)
#24
I'm still not giving $400 for a cam.![The Judge](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_judge.gif)
#26
what a rush!
Originally Posted by 02sierraz71_5.3
Ive never bought into the whole xer style lobe idea, neither have I seen any graphs comparing the same cam one with symmetrical lobes and the other with xer type. I think its a marketing gimmic and plus they are alot harder on the valve train.
my .02
my .02
![Driving](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_driving3.gif)
#27
1slow what is your static compression, stroke and rod length?
![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
Guys lets not turn this thread into a pissing match. I chose the cam I did cause it had the numbers that I wanted, the price I wanted, and it was supposedly readily available(took way too long) and its in the motor and the motor is in the truck and it aint comin out
I will be doing a cam swap on this motor this summer so we can argue over what I should go with then when I dont already ahve the cam installed
#28
Your gonna have a time tuning for that cam on 93 octane, your dynamic compression is gonna be over 9.5:1 and that cam has a huge amount of overlap. It should really scream in the high rpms I just hope youve got a bullet proof valvetrain and its titanium. I dont want to see you blow that motor up, stroker motors arent considered high revving engines for a reason. I would take it very very slow.
I would also make sure your quench area is nailed down to .040
that cam looks like its designed for race only applications
#29
I consider it a moderate street cam in my opinion. I have ran larger cams than that on every day driven street engines that were solid roller(carbureted). Nevertheless, it is basically the same cam that is in 2bseen's 408 and Gomer has it tuned nicely. It is even DBW throttle body and he has the idle nailed down. Nelson is doing the tune on Cody's truck and from what i've heard he has tuned several 408's with similar cams.
It's a 6.125" Gen1 SBC rod.
#30
My calc says dynamic is at 9.635, Ive always heard that you dont want to go over 9.0 for a street motor on 93.
