cam suggestion
Old 08-02-2006, 06:46 PM
firervfd37's Avatar
Default cam suggestion
ok...i am looking for suggestions on a cam for my 06' silverado v-max. lq9 6.0l, 3.73 gears, soon to have a custom tune, corsa sport exhaust, and outlaw cai. i want basic stock idle but some performance increase. any thoughts?
Old 08-02-2006, 10:39 PM
Pjstucn's Avatar
by stock idle do you mean no sound difference at idle or no rpm defference at idle?
Old 08-02-2006, 11:44 PM
search buttom up top works well
Old 08-03-2006, 02:35 AM
Mr. Sandog's Avatar
With the stock converter I'd go with the old 6.0L standby:
Comp 212/218, 559/563 on a 115.
For a little more stock idle just have it ground on a 116 and while you're at it get 4 degrees of advance ground in...Comp doesn't charge any more for a custom grind than they do an off-the-shelf grind.
Old 08-03-2006, 12:54 PM
Coban's Avatar
That 212/218 would be excellent, just make sure you get the hilift version.
Old 08-03-2006, 09:51 PM
firervfd37's Avatar
sounds good...but the only problem is you all keep talking about lifts and stuff and i have no clue what these numbers are haha. i am a moron when i comes to this ****. thanks for the info. though
Old 08-03-2006, 10:30 PM
Destroyer of Transmissions
1SlowHoe's Avatar
Youre gonna want better springs with that much lift.
Old 08-03-2006, 11:27 PM
... he doesnt know what lift is.
Old 08-03-2006, 11:59 PM
Pjstucn's Avatar
^ what he said.
Old 08-04-2006, 01:03 AM
Mr. Sandog's Avatar
You need to read up homes... CAM GUIDE CLICK HERE BRING COFFEE
Quick Reply: cam suggestion
