Is this Cam Too Big For Towing?
Old 06-11-2012, 02:21 PM
nonnieselman's Avatar
if your tune is good, it should be just fine.
Old 06-11-2012, 02:24 PM
Come Get Some!!
Ford_Assassin's Avatar
Its kinda sad that the 6.0 will make more power in the K5 since it has LT's (block huggers in the Z) and running the truck intake which makes more power vs a factory LS1 intake.
Old 06-11-2012, 02:43 PM
Gotta run what will fit.
Old 06-11-2012, 07:45 PM
old motorhead's Avatar
I have a 222/230 115lsa in my 6.0L 5000lb half ton. Tows the hell out of my 4K lb bay boat. With a good tune, you shouldn't have any trouble. I have a TVS on mine, but can still accelerate pretty smartly without getting into boost.
Old 06-11-2012, 10:02 PM
pewterliftedz's Avatar
thats not a big cam at all for a 6.0. should pull pretty good.
The real wuestion is what cam is going in the 5.3 that you'll need a 4k converter haha..
Old 07-19-2012, 05:40 AM
Come Get Some!!
Hey guys, ended up leaving the 6.0 in the Z and selling it.
Had some change left over and bought a Roush (same as SLP) TVS 1900 supercharger kit with less than 5k miles on it.
Finished installing it a few days ago and got it dyno tuned yesterday, very pleased with the results. Thinking about the LS9 cam now.....
Old 07-19-2012, 08:15 AM
Vortec350ss's Avatar
Problem solved!! That will give you the power where you need it!
I would think about a custom cam for your set up, or look into something like the vinci trucker. The LS9 cam will be the most civil, but there are other came out there that will give up the smooth idle (i wanted to with my cam swap anyway... it was part of the attraction) or possibly a little gas mileage in favor of a little more power.
Old 07-19-2012, 09:14 AM
Come Get Some!!
Actually I was kidding about the LS9 (the wink). You are correct though, if I were to change the current LS6 cam out for something else, it'd be a custom grind in the 0.600" lift range, below 225 duration, and a 114-116 LSA. But at this point I am pleased with the power and I'd like to keep the smooth idle too (hence the 'Ghost' nickname).
Bluecollar Hotrods
06-11-2024 11:37 PM
Oobray
06-13-2022 03:38 AM
2500ZL1
01-25-2016 06:30 AM
Dirtywhite
08-05-2015 04:10 PM
low2001gmc
07-23-2015 05:10 PM
Quick Reply: Is this Cam Too Big For Towing?
