Camming 4.8
Old 04-10-2013 | 12:18 PM
sam72104's Avatar
Default Camming 4.8
Hows it going guys? i got 2006 silverado reg cab that im about to install my cam in. so far. what i have is.
GOING IN:
Comp Cam - 54-456-11 / @.050 219/227
Push Rods - 7955-16 / 7.4's
Dual Spring Kit - 26921-KIT
243 Heads
LS7 LIFTERS
I NEED:
Timing Chain
Gasket Kit
Might be forgeting a thing or two. Tell me what you guys think about the set up. might getta turbo later on.
The truck as it sits has a few mods.:
P&P throttle body
Headers - Full exhuast
HP Tune
4.10 Gears
Detroit trutrac
Performabuilt LVL2
YANK 3600
Cold Air Intake
Old 04-11-2013 | 10:40 AM
lycominghunter's Avatar
I don't know much about deciphering cams and their parameters, but stock pushrods are 7.4". LS7 Lifters are slightly higher than stock lifters so that will adjust your pushrod length. Additionally, depending on the cam, your pushrod length might need to be adjusted too (I'm not sure if it will or will not need to be). Also, I don't know if you have had your heads milled at all, but that as well would affect the pushrod length.
Another thing that you might want to research is whether or not your cam is boost compatible since you may be adding a turbo eventually. Hope that helps. What were you going to get gaskets for?
Old 04-11-2013 | 02:36 PM
low2001gmc's Avatar
sounds good to me so far. like mentioned above you might want to see if cam will be compatible with future turbo. turbos usually like lsa in the 114-116 range.
Old 04-11-2013 | 10:27 PM
craigsix's Avatar
you should be able too reuse your old lifters.
Old 04-14-2013 | 11:48 PM
sam72104's Avatar
comp cam set me up on the cam and push rods and such, and the guy who own kk performance said everything looked good to him, but i never said anything about a turbo..
ima check it out, i hear of people putting almost identical camshafts as mine with spray. lmfao
thnx, and i wil doo and yeha this one is only 112
i dont wanna use the old ones, i wanna replace them while its tore apart
Old 04-15-2013 | 09:22 AM
Camin00's Avatar
You dont have to replace gaskets except the head gaskets, but like you said since it is tore apart go ahead.
What I replaced. head gaskets < you could spend the extra money and get cosmetic gaskets .04 to bump compression up. You will lose some compression with non milled 243s. Timing cover gaskets, front crank seal, intake manifold gaskets, water pump gaskets, and header gaskets. I found it cheaper to buy the gaskets individually rather than a kit.
You wont be able to swap the chain with out droping the oil pan and pulling the oil pump off. My truck had 150K when I did my swap the chain wasn't to bad. I put my ls2 cam sprocket on and it removed some slack.
Please please please get a comp-cam push rod checker. I didn't and have been battling lifter tapping. I just got it figured out the other day.
That's a good cam choice for N/A motor with your gears and stall
Old 04-15-2013 | 09:24 AM
Camin00's Avatar
you will also need special little plastic ring tools to remove the fuel lines from the intake manifold.
Old 05-23-2013 | 10:45 PM
sam72104's Avatar
got it all together all it needs is a tune Cammed 4.8 - YouTube
Dan Neumann
11
08-07-2022 10:06 AM
JordanH
08-08-2015 08:59 PM
Castro45
24
07-31-2015 08:13 PM
Suburban2500
07-19-2015 05:50 PM
06 4.8
07-15-2015 08:17 PM
