changing a 5.3 block to a 6.0 using same accessories
Old 11-29-2009, 12:37 PM
11 Second Truck Club
MPFD's Avatar
Originally Posted by misfitfsk
got it, converter with the 2500 flexplate60 snout and a 80 backing plate. thanks!!!!! thanks MPFD dint want to get rid of the stage 2 60e when it only has 500 miles on it.
i went and bought the 6.0 block, crank, rods & pistons with cam. brought it home last night and tossed the cam out. (anybody looking for a stock 6.0 cam?) after getting that stall made i think ill be good to go. any other little details i should encounter. now that i have the block im getting anxious.
Only if you have the longer crank will you need the 80e flex plate...
If the crank flange is flush with the back of the motor you will need the dished flywheel.
Raggedz71
07-29-2016 10:20 AM
B.love18
09-21-2015 08:31 PM
steves86ta
07-28-2015 10:21 AM
Choda
07-21-2015 03:47 PM
ferrellrooster
07-13-2015 09:53 AM
Quick Reply: changing a 5.3 block to a 6.0 using same accessories
