Chevy 4.3 liter v6
I sadly say I drive a v6 fullsize lol. I have a K&N CAI, exhaust cut-out, and a tune from thunder racing, and ran a 15.8 with spare tire out, tailgait off, and passenger headlight out.
I have a cam sitting in my room that I ordered from summit (.260/266 .500lift with 112 lsa). All I need to order is springs and its going in. I will shave the heads when I take them off for the cam swap too Also going to port the throttle body while im at it.
When that goes out, a stock 6.0 with a t56 is going in.
As for comparing to 5.3's for now, I would stick to racing stock 99 model silverados.
13 Second Truck Club
Right now I can out run stock to little modded 4.8- 5.3's. I try to stay in the 99-02 range though with theses series of motors. I ran one 4 door 4.8 with LTs, and tune, and beat him off the line, but got passed at 70 mph.
I try to mod the truck to where the 6.0 can get some too. Example is in the next few weeks I am going with 4.10 gears and a posi unit. I already have a stock exhaust with a cutout to bolt right in place
Cam and springs will go in during the summer while I am at UTI.
i did a 4.3 build it was my first build do your research on cams i beleive the earlier blocks take a different cam i had the wrong cam for the wrong block all i did was bore .030 over change the dish pistons in and put a medium sized cam and a edelbrock 4 barrel intake and an edelbrock 500 ran awesome but you cant build a good car working after school at a parts store it cuold have put down some good times with a stall and slicks motor made tons of tourqe the heads needed porting bc it ran out of steam around 5800
