cleaning deposits on 6.0 pistons
the pistons on my new motor have some carbon buildup on them. Would it be OK if I blasted them with carb cleaner and wiped them down?? Im worried about it dripping down the cylinder walls....
When you asked me about it before I was assuming you had the engine apart. If you are worried about the carbon on top of the piston I would just scrape the heavy stuff off and leave it at that. They will get carboned up again within the first few thousand miles anyway.
Originally Posted by greentahoe
sounds good. Maybe the meth will help to clean them a bit as well. Should I coat the walls with the mystery oil as well?? Or should I just do a light coat of Mobil 1? I really appreciate it!
Originally Posted by Danville Performance
I would clean them if you have it apart so they will be equal compression across the board or as close as possible. It would be like having the oilpan off and not removing the sludge in the bottom before reinstalling it.
05GMC4.8
08-07-2015 10:55 PM
