cleaning intake?
cleaning intake?
Just putting engine back together and wanted to clean the intake up. It is the stock intake from the truck and was wondering if I can have this jet washed at a machine shop or not??? This is the plastic style intake. Thanks
someone on here the other day said he put foaming engine cleaner in it and let it sit for a while then holes it out and dried it with an air compressor and wiped it out as best he could. he mentioned his hands could fit inside. i would imagine he made sure everything had a chance to evaporate too before he put it back on
Another question, where else is there a vacuum port on the stock intake? The factory has the one for the fuel regulator and there is the other one on the opposite side that I am already using. Can you drill another hole and put a fitting in the intake somewhere for another vacuum port??? Thanks for all the info on the cleaning!!!
PT's Slowest Truck
GXPJAY
02-13-2022 08:15 AM
Corvette454l88
09-01-2016 01:24 AM
Fast86z
08-23-2015 12:35 AM
05GMC4.8
08-07-2015 09:55 PM
Suburban2500
07-14-2015 02:10 AM
