comp 218 low lift vs.eps truck tq cam for a 4.8.
Old 01-31-2012 | 01:06 PM
sierra69's Avatar
Question comp 218 low lift vs.eps truck tq cam for a 4.8.
I am try to steer another co-worker in the right direction in cam choices for his 08 sierra wt cc 4x2.he hauls wood during the winter than hauls his quads during the summer.so if you guys can chime in and help me help this guy out that would be great. i told him anything bigger than a 220 cam would be a slug.everything is stock on his truck except for a cai and a magnaflow muffler.
Old 01-31-2012 | 01:15 PM
jrmchevyman's Avatar
Comp 212/218 low lift would be my choice also since it is a heavy truck, 4.8, will be used for towing, and he will be keeping everything stock like the converter and gears.
He could bump the cam up more and be happy IMO if he upgraded the converter and possibly changed gears depending on what he currently has and what size tires/wheels. Also if he did that I highly suggest a bigger aftermarket tranny cooler.
Also, Another alternative cam vs the comp 212/218 would be one of the Vinci towing cams.
Old 01-31-2012 | 01:25 PM
sierra69's Avatar
He's running 265/70/17 and the stock 3:23s.
Old 01-31-2012 | 01:56 PM
jiar577's Avatar
If he has a 4l60e I'd get gears first, with that tire size either 3.73 or even 3.90 should work and be more noticeable than a cam IMO.
If his truck already has the 6L80 my post is irrelevant.
Old 01-31-2012 | 02:34 PM
sierra69's Avatar
He said he has the 4l60e and is alreay having the eaton lsd and 3:73s done this weeked.i talked him out of the tci t/c and is now surfing circle d website.
Old 01-31-2012 | 03:08 PM
Yes, there are many other better alternatives than TCI. CircleD 278mm would prob be perfect for him and they are very affordable (only $375) with the promo code. FTI, Yank, PI, Coan, etc are just a few others that are good as well, but some of them can get expensive.
Old 01-31-2012 | 05:01 PM
jiar577's Avatar
212/218 low lift should work great with that combo
Old 01-31-2012 | 05:21 PM
07blakchevy's Avatar
Promo code?
Old 01-31-2012 | 06:03 PM
sierra69's Avatar
Originally Posted by 07blakchevy
Promo code?
x2 promo code
Old 01-31-2012 | 06:27 PM
LS1TRUCKGUY's Avatar
just call circle d and talk to chris. tell him you are a pt.net member....
wrb002
08-31-2015 12:00 PM
Castro45
24
07-31-2015 07:13 PM
black6spdz
07-16-2015 01:32 AM
GRRR65GTO
07-10-2015 08:27 PM
Aboss
07-09-2015 10:28 AM
Quick Reply: comp 218 low lift vs.eps truck tq cam for a 4.8.
