Comp 918 springs with XR265 cam.. valvetrain noise
Old 10-02-2008, 11:09 AM
  #21
PT's Slowest Truck
budhayes3's Avatar
Originally Posted by hirdlej
After playing with my 4.8L on the engine stand, I grabbed a rocker that's at full rest and it wiggles from side to side. It clicks as there is side to side play from the needle bearings (naturally there has to be). I would think the 918's over the LS6 springs have a considerably higher amount of seat pressure at rest. This in fact is putting more stress on the rocker so you are going to hear that clack or side to side movement as the rocker leaves and returns back to its resting position. I believe it to be the nature of the beast. Maybe this is moreso heard than the initial theory I had of the valves slamming onto their seats.
I tested that theory by replacing my old Comp 915 springs and factory rockers with LS6 springs and Harland Sharp 1.7 rockers, my noises did not change...and I have a baby cam.
EDIT - my noise may be lifter related though? Either way, it's been noisy like that for 13k, so as you mentioned it's just the nature of the beast.
Old 10-02-2008, 11:22 AM
  #22
zippy's Avatar
The 918's are 130# at rest and the LS6 springs are 90# at rest. They get closer as they compress, but less at rest. GM probably wanted them that way to quiet them down.
The 915's have almost the same spec's as the LS6 springs. I'd guess they'd make about the same amount of noise.
Old 10-02-2008, 12:37 PM
  #23
PT's Slowest Truck
budhayes3's Avatar
Interesting, for some reason I thought the 915's were stiffer.
Old 10-04-2008, 10:50 AM
  #24
norris_83's Avatar
so i take it even if i change out the pushrods for slightly longer ones, there's no way of getting rid of this sewing machine of an engine, unless i change the springs out to something like the 915s?
Old 10-04-2008, 11:40 AM
  #25
Where's the Beef?
viciousknid's Avatar
Get a clip of just how noisey your talking about. Mine isn't loud enough to bother me.
You can always just get a louder exhaust.
murderedSS
27
10-12-2015 11:13 AM
jtphelps289
09-29-2015 12:00 PM
chvy=power
09-08-2015 11:06 AM
USMCvet0311
09-04-2015 09:43 PM
LT-1 SS
09-03-2015 10:24 AM
Quick Reply: Comp 918 springs with XR265 cam.. valvetrain noise
