Comp 918s and 601 lift?
I know someone that had less then 10k (way less just being conservative as I don't know the actual mileage) and the springs were already weak enough to missfire at idle with a .58x lift cam. I prefer duals.
spend 50-100 more for a known good working dual spring. Not trying to tell you that you're dumb . . . but spend the extra now for springs vs new pistons and valves or a whole head when a spring fails and wipes out your beloved new engine build.
PAC is about the only single spring that I would recommend using.
10 Second Truck Club
Looks like the comps are out. My 4.8 currently has PAC beehive springs in it and 30k later no problems and im not nice to it either. I cant afford these forged pistons to slap a valve due to a spring crappin out so im going to start looking for some dual valve springs.
Thanks guys
Frank
Thanks guys
Frank
