Comp vs PAC
Old 05-01-2009 | 05:09 PM
lucky77's Avatar
Banned
Default Comp vs PAC
whos running this springs.. . which ones would you go for?
http://www.pacracing.com/Beehive_Spr...Set_of_16.html vs.
http://www.compperformancegroupstore...egory_Code=BEE
Old 05-01-2009 | 05:21 PM
GMCtrk's Avatar
Overall the 918 is probably the most popular spring. But most will tell you to go with the 1218. That's what I run; if I could do it again I'd do the 1518...I'm limited on cam choice and a lot of the new grinds use lift over .600". There seems to be more failures with the 918's, but then again, more people run them I believe. There's also the issue of installing them at the correct height....
Old 05-01-2009 | 08:28 PM
budhayes3's Avatar
PT's Slowest Truck
What's this issue you speak of?
Wolftrk99
10-02-2015 09:17 AM
Velocity1
10-02-2015 09:01 AM
jtphelps289
09-30-2015 10:26 PM
sTNT971
09-26-2015 05:22 PM
