Compression Help
Compression Help
I know I need to determine Static Compression as well as Dynamic in order to see how well my cam will suit the build but right now I'm trying to determine if the rotating assembly i'm going to build will meet my DCR goals and then I'll see if the cam puts the SCR where it needs to be.
Does all of this look right? I'm really not sure about the Block Deck Height and really only guessing on the Piston compression height. I plan on running L92 heads milled 030 N/A and then swapping to non milled 71cc L92 heads later if I run F/I. I Really need to get around to ordering the rotating assembly so I need to make sure these numbers are right so I can get it ordered.
Here's what I Think i need to order on TSP's site:
Here is what I think the CR is going to be but again need help with the Piston compression height and the deck height to be sure. My goal is to have a 10:1+ CR with milled 030 L92s and 9.5 ish with stock L92s
zblee
11-11-2015 12:41 AM
