Confused
Confused
I know everybody on here has said its been beat to death and such but ive done some researching looking up articles and different things and still don't know which route to go
1. Single turbo set up? forged internals? if not how much boost would i be safe with?
2. All motor? what set up would get me close to 400hp? or little less little more?
3. Nitrous, forged everything or just pistons?
Just need a little guidance
00 extended cab silverado Daily driver,but if it cut gas mileage to bad i would probably make it a weekend warrior and get something cheaper on gas but i dont mind loosing a little mileage
also considered a 6.0 build, i can get one that includes block and crank,rods,pistons....but im worried if i build it im worried about having it wired then having to redo fuel system where as if i just build a 5.3 its plug and play
No need for forged internals on these engines, unless you start to get serious with FI. You see guys on here and other sites with the lil 4.8L LS engines making 600 to the wheels on stock blocks.
Just get a KB front mount kit with a 70 or 76mm turbo and run it at 5-7psi to start you off. Then you can go from there.
Or you could do a 6.0 with cam, headers, new heads or head work and intake for a N/A build.
question with the 6.0 build..i can get it for $100 bucks, how bad would it be getting it wired and all that good stuff...would i need harness or could i cut into my 5.3 harness? just concerns like that with the 6.0 build
you answered my question that i had in that last post...whoops...yeah i have a little honda civic if it gets to bad...well what suggestions with the 6.0? cam? head choice and what to do to them? intake?
It all depends on your overall goal. How often do you plan on taking it to the track? Or is street racing your thing? You really cant go wrong with FI. Just keep it under 10PSI of boost. Have a look through this thread to help you figure out what you want.
https://www.performancetrucks.net/fo...sts-vs-356429/
