Connecting Rod Math question?
Need a sanity check on my math:
Since there are "stocked" pistons made for a 4" stroke Crank using a 6.125" Connecting Rod.
Shouldn't I be able to run those pistons with a stock stroke crank(3.622") and a 6.314" connecting rod or there abouts?
To tell where the piston will wind up in relation to the deck, I always use deck height-1/2 stroke-rod length-comp height. + number= out of the hole, - number= in the hole, 0=zero deck.
So with the two compression heights being the same:
9.245"-2.00"-6.125"-X=9.245"-1.811"-6.314"-X
You are correct sir, but where are you going to get a rod with that exact length? Custom? Titanium perhaps?
Originally Posted by mjhoward
That is why I suggested the 4.8 rod.
A custom set of pistons and stock rods would be a lot cheaper than pistons and custom rods of course as well.
You could run a 4.8 rod (6.285) and deck the block .030 and have the same thing for a lot less money.
Originally Posted by vanillagorilla
Those would put him about 0.029" in the hole, assuming the off the shelf stroker pistons are at zero deck with the 4" stroke/6.125"rod combo. It'll drop his compression ratio quite a bit too.
"wouldn't you run into some piston rock unless tolerances were dead nuts on???"
The length of the skirt controls that.
5.3lSilverado
25
08-29-2016 12:48 AM
hartinclay
08-02-2015 06:44 PM
bbowerman
07-26-2015 10:57 PM
