Counter Revolution Engine
I think because the rule makers keep changing the engine size and configurations, even the factories are having trouble funding constant redesign. Czysz is now developing an electric bike.
http://www.motoczysz.com/club/
Kinda shady if you ask me that MotoGP would change the rules the first season that the only American sport bike company wanted to enter.
They were trying to make it "safer" by slowing it down with smaller engines but the riders are still breaking lap records almost every race due to higher corner speeds and just evolution of the bikes.
I can just about assure you that had absolutely nothing to do with the rule changes.
Ohhh gotcha! I don't follow it much except for maybe stumbling on a race here or there but do enjoy watching it. It is a shame that they couldn't enter when they were planning it though!
The advantage achieved within a motorcycle frame was that there is no longer a tendency for the motorcycle to right itself when you get on the throttle when in a hard turn. The gyroscopic effect of the crank on most bikes causes a leaning bike to become upright in a corner if too much throttle is applied or if a driver is not strong enough to keep the bike leaned over. With this design the bike can remain in an hard turn and you could literally go full throttle and you would not have the bike trying to rip you upright.
Them's all might purty words, but the effect is to lessen the gyroscope's resistance to changing direction. If you have dirt bike experience, you know that a 450 turns the hardest, a 250 is easier, an a 125 the easiest. Although a 250 (two stroke) is only about 15 lbs heavier than a 125, most of the difference is in the crankshaft. When you try to forcefully turn them, the 125 feels 50 lbs lighter, because its gyroscope is so much smaller.
The C1 takes an inline four and mounts it longitudinally, vs. the transverse setups found in most motorcycles.
They change it up by slitting the four into two parallel twins. The crankshafts spin in opposite directions, effectively canceling any gyroscopic tendencies found in an engine with a crankshaft spinning only one direction. Plus, if I remember correctly, the two banks of cylinders are on a 15* included angle.
Czysz also had some really trick linear bearings on the forks to virtually eliminate sticktion caused by regular telescopic forks.
From what I've read he's building an electric motoGP bike...
superchomper2003
08-26-2015 09:39 AM
Allgonoshow
08-25-2015 02:56 PM
GMCtrk
38
08-09-2015 08:50 PM
85SS/85GN
07-22-2015 12:48 PM
