Cylinder/piston lubrication on startup for a rebuild
Hey all - question on cylinder/piston lubrication on startup. When assembling my new engine I had read to break in the engine using ATF as the cylinder lubricant to ensure proper ring seating to the cylinders.
I have since seen the use of ATF to clean the cylinders but to also lubricate with engine oil during assembly.
Since I didn't add the engine oil here is my question....
When priming the engine I plan on using a pressurized oil source and rotating the engine by hand first to ensure the lifters/cam/crank/rockers/valves all get oil. Will this be enough to lubricate the pistons in the cylinders as well? Should I squirt some oil in the plug hole and rotate in addition to that?
thanks for your help.
Ken
Ken
Another thing to do is to pull fuel pump fuse or disconnect your coils and crank it over with the starter... Gets oil moving via the oil pump which will fully lubricate the engine while you crank it.... When i install my pistons i coat the cylinder walls and rings with oil and drop em in, so long as they werent dry going in youre fine....
TwiZtedZ71
03-15-2016 06:41 PM
Slammed silverado
17
03-07-2016 09:22 AM
omalley1537
02-27-2016 02:27 PM
