D.o.d. Cam swap
D.o.d. Cam swap
Well here in the next week or so, I'll be doing a D.O.D. Cam swap.... while the heads are off, what should I do? being as I will have direct access to a machine shop.... What do you suggest??
LY5 5.3
TR224 Cam
918 Springs
TR hardened push rods..
2800 Stall
PCMforless tune
underdrive pulleys
CAI
3.73
NBSCC
To do list.
lt headers
Boost valve
scat trak
Aux Cooler
(lookin for a 2nd hand blower / turbo)
LY5 5.3
TR224 Cam
918 Springs
2800 Stall
PCMforless tune
underdrive pulleys
CAI
3.73
NBSCC
To do list.
lt headers
Boost valve
scat trak
Aux Cooler
PT's Slowest Truck
If you already have the valve springs, I'd return them and get some PAC 1218's. I've read way too many threads both here and on LS1Tech about 918's breaking. You're going to want more converter than 2800 for a TR224 in a 5.3, something like a 3200-3400 would be better matched.
I suppose that you could always mill the heads to bump the compression up a bit, since you'll have them off and have access to a machine shop. Maybe .030? You're going to need some shorter pushrods though...
Cam swap w/AFM
DontLetItFoolYa, I would like to know if this swap is possible. I asked the question to CompCams and this was their response;
You would have to deactivate the displacement on demand in order to change
the camshaft we do not offer anything that will work for that.
That was the end of the discussion but now I see a couple guys mentioning replacing the lifters of which in some kits come with the cam and the lifter valley tray. I was looking at the XFI 260 fm CompCams. I have the 5.3 in a 2007 SLT 1500 2WD. It seems this engine w/AFM is a deadend when trying to get a little more horses out it. I like the truck but will not buy another with AFM..
You could always check the lifters to see what the maximum lobe lift value is for the pushrod slip cup (just what I'm calling it). That's the unit that slides into the body of the lifter when the D.O.D. solenoids activate and let the lifters follow the cam without creating lift. Once you find out what this value is, allow maybe .010-.015" of clearance and find a cam with that amount of lift. This way you can keep the DOD lifters and the feature afforded to the engine by them. Check that your ramp rates on the cam and the required spring rates aren't to crazy, I believe there is a max load that the lifters will take.
I too am planning to do a cam swap on a 2007 5.3 LY5. I plan to keep the DOD. I spoke to Lunati technical assistance and he advised me there may be 2 grooves on cam journals #2 and #4 for upper lifter oiling. If this is the case the new cam will have to be machined for this. Not a big deal he said, one day turn around. He also said it will work with the stock set up other than the cam sprocket. I have read different posts saying to switch to a LS2 or a LS7 sprocket. Both have different part numbers. Anyone know for sure?? I see Lingenfelter sells a kit with a sprocket, bolts and chain tensioner to use a 3 bolts cam. Anyone used this kit?
The 2006 LS2 and LS7 use the same 3 bolt cam sprocket. The kit Lingenfelter sells is OE GM parts with a higher price tag. I can pick up the sprocket and dampener at my dealer for $32.00. I will be doing the cam swap here later this month. I will post results. If anyone else has any info or input please post.
